Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
image seq not working
6 REPLIES 6
honorsforgod
210 Views, 6 Replies
hi
i am using the latest version of cinema and Arnold and I have this issue
image seq aka animation not rendering in image viewer (final render) having said that its works
in IPR and viewport
Tags (2)
Labels (1)
6 REPLIES 6
It's working fine in my quick test. When you say 'animation is not rendering', does it mean that the first frame of the sequence is rendering in all frames? Picture viewer and IPR uses the same code, so if works in the IPR, I don't see why it does not in the Picture Viewer.
Can you reproduce it in a new scene just with the image sequence? Feel free to share the scene, and I'll take a look.
// Peter Horvath
// C4DtoA developer
Hossein_SHA
in reply to: peter_horvath
Yes i meant : first frame of the sequence is rendering in all frames
Yeah i am sure it’s work in ipr but in pictures viewer not working
What if you use # characters in the path, does that make any difference? Like 'myimage_####.tx' instead of 'myimage_0000.tx'. You can also check the Console if there are any warnings or errors.
// Peter Horvath
// C4DtoA developer
Hossein_SHA
Hmmmm,That’s interesting I will try it
Hossein_SHA
It’s worked with ####
thanks
peter_horvath
in reply to: Hossein_SHA
Interesting, then could be a problem with the logic detecting the frame number in the file name. Can you show me the original file path in the image shader (without ####)?
// Peter Horvath
// C4DtoA developer
Technology Administrators
