Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
image colour variation query
2 REPLIES 2
alexhammond
202 Views, 2 Replies
Morning
I'm getting some funny changes with the appearance of textures.. i'll try and explain...
Setup 1
image node piped straight into Beauty - image is represented exactly as the original jpeg.
Setup 2
image node into base colour of a standard material
+ image node with alpha into cutout opacity channel
then this goes into the Beauty.
For setup 2 there is an subtle desaturation of the image even though the standard surface parameters (as far as i can see are zero'd or max'ed out)
So.. Is there a trick to getting the image output in Setup 2 to be accurate
or
is there another way to add an alpha cutout when using just the image node direct to beauty.
Thanks for any thoughts
Alex
Tags (1)
Labels (1)
2 REPLIES 2
If you pipe the image into the beauty, you basically get an emissive surface, affected by no lights. While connecting the texture to the base color of a standard shader it represents a diffuse layer affected by the lighting. That's the difference between the two setups.
If you really need an emissive surface/look, you can connect the texture to the emission color input of the standard surface shader and turn off base and specular.
alexhammond
in reply to: alexhammond
Amazing - I knew there would be a way - Thanks kindly
