Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
I have a problem with c4dtoa about how to render A glass bottle with water
12 REPLIES 12
Message 1 of 13
719 Views, 12 Replies
when render a bottle with water ,I found a huge part of bottle is black .I followed the 'rendering glass surface with Arnold ' in arnold for c4d guide to modeling ,but its no work .I want to know how to remove it
Tags (1)
Labels (1)
12 REPLIES 12
Message 2 of 13
lee_griggs
How does it look without the liquid? Are the normals facing the right direction? Transmission Ray Depth is high? Did you scale the liquid up?
How does it look in the glass bowl or studio scenes here?
If that doesn't work, please upload the scene.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 13
crasse2
try with an arnold sky (just with a white texture for example, and make it only visible in reflection and refraction if needed) black parts maybe because you have no background, so the liquid material has nothing to refract.
Message 4 of 13
aaronfross
Specular Ray Depth also needs to be high... it needs to be at least 4 to avoid dark areas.
Message 5 of 13
Just invert normals....go to polygon mode and right click on the object then look for reverse normals and cliclick it.
Message 6 of 13
in reply to: lee_griggs
thanks ,I have a new question about it ,Could you answer?
Message 7 of 13
lee_griggs
Where? Can you reply to the answers here first, please?
Lee Griggs
AUTODESK
Message 8 of 13
thanks everyone answer my question ,I changed the HDRI sky and the normal direction is right ,but its doesnt work,When I turn up ray depth and transmission ,its come to use,at the same time ,new question have arisen ,The body of bottle and bottleneck is too dark.In order to remove black part ,I have to turn ray depth up to 14 or more,and rendering time take long to three time as long as,isnt that too long? is there another way?
Message 9 of 13
here you are
Message 10 of 13
???where is my question
Message 11 of 13
I dont why the question disappear ,
Message 12 of 13
look this picture
Message 13 of 13
lee_griggs
Isn't it dark because it's just refracting the black areas in your scene? Add a sky/HDRI or model something to reflect/refract in the bottle.
Lee Griggs
AUTODESK
Technology Administrators
