I cannot find contour filter in Arnold render settings window.
ronghe_dai
ronghe_dai
I use c4d on Mac and cannot find contour filter. it's missed.
peter.horvath6V6K3
What's your plugin version? I can see the filter in that menu on my mac.
ronghe_dai
thank you:) the version is 2.3.0.
peter.horvath6V6K3
All good with that version here:
Maybe something is wrong with your installation? The toon shader appears fine, right?
ronghe_dai
yes, no problem with the toon shader appears at all. I installed twice in last week but nothing helped with the problem. it's so confusing.
peter.horvath6V6K3
What happens if you try to add the Contour filter from the toon shader UI? Is there anything in the log (console)?
I wonder what happens if you remove or rename the plugins/C4DtoA/c4dtoa.mtd file.
Also it would be interesting to see if the filter is listed when you run kick from the command line (C4D_DIR is your Cinema 4D folder):
C4D_DIR/arnold/bin/kick -nodes n
