Here is an example. How are you connecting it (images please)?
The layer RGBA shader is for texture type shaders only (e.g. image, noise, etc.), so you can not connect a standard shader to it, which is a surface type shader. You can not mix texture and surface type shaders, this is a technical limitation at the moment.
