How to properly bake a texture in c4dtoA?
Djeisoncanuto
Message 1 of 10
Djeisoncanuto
So, I have been trying to output a diffuse pass of a somewhat heavy layer stacking for the color channel. So, that I may bring it back in to have a lighter shader build but when I export I get a "texture is finished successfully but I don't see the outed file in my folder. I'm not sure if I'm doing anything wrong.
Replies (9)
Message 2 of 10
peter.horvath6V6K3
Make sure your object is enabled. For instance if it's under a Cloner, it won't be exported to Arnold.
Define the UV Set only if you have multiple UV sets on the object and you want to use a cutom one. If you just want to use the main UVs, then leave this field empty.
Message 3 of 10
Djeisoncanuto
Thank you! The cloner was the issue! Thank you so much! @Peter Horvath
Message 4 of 10
peter.horvath6V6K3
This is definitely something I should improve in a future version.
Message 5 of 10
Djeisoncanuto
Lets get that Arnold GPU first hahaha jk. Looked amazing at Siggraph on the threadripper 2 and Quadro RTX 6000!
Message 6 of 10
MOHAMED_ABOELENIN
HOW TO GET IN TO THIS MENU ?
UNDER WHAT ITEM IN THE PROGRAM ?
Message 7 of 10
kamp3d
Observer
Observer
Are there any tools to bake displacement map from Arnold shader network? I ofter layer various image maps and tiled procedurals to achieve the looks I need which result in long render times. Am I over looking anything in Bake Texture AOV's?
Message 8 of 10
peter.horvath6V6K3
Texture baking is limited to shading, so baking displacement map is not possible at the moment unfortunately.
Message 9 of 10
Is anyone getting inconsistent results from baking textures??
Message 10 of 10
demodunk
Under utilities.
