Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
How to offset the effect of displacement maps on geometry in the C4D viewport?
2 REPLIES 2
daniel2SH2D
279 Views, 2 Replies
Hi - perhaps an obvious one but it has me stumped:
I have a ground-plane object with a displacement texture applied, not too much, but it clearly *moves the plane* in the Arnold IPR, while leaving the geometry in the C4D viewport in the same place (let's say at Y=0). So, C4D Y=0, but in the IPR the plane is now at Y= something else.
So then placing objects on the plane leaves them 'hanging in space' in the IPR, as the plane is now at Y= minus 12, (approx), or, depending on the displacement, sunk in to the geometry in the viewport.
Is there a workaround for this? Or do you just have to 'eyeball' it in the IPR and accept intersecting geometry or floaty geometry in the viewport? How to keep objects with the same Y co-ordinates 'resting on each other' in the viewport when displacement is applied? Or rather, how to ensure the displaced geometry still has a useful co-ordinate system in the viewport?
Labels (3)
2 REPLIES 2
daniel2SH2D
in reply to: daniel2SH2D
testplane.jpgTest plane yellow @ Y=0
displaced-plane.jpgDisplaced plane @ Y=0
viewport.jpgViewport to IPR mismatch for useful co-ordinates
daniel2SH2D
I think I've sussed it out...
The Scalar Zero value just needs to be adjusted until the Y=0 parts of the map are, in fact, at Y=0...
I was just leaving it at 0.5 and assuming that's 'correct', but it obvs depends on what shade of gray has been used for 0 in the actual map!
Then use the Arnold tag to play with height and padding until the look is whatever you want.
If that's wrong, please let me know! thx
