Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
how to make a more uniform and darker reflection?
2 REPLIES 2
mail.nicholas2006
197 Views, 2 Replies
Hello, I have setup a floor with a texture image set and trying to capture both shadow and reflections from white&black ball. Since "standard_surface" material renders the image that I want a bit darker than it should be, I just imported it on "image" node (in the attachment, it will be a checkerboard instead) and linked it to "shadow_matte" node to capture both shadow and reflection. However, I cannot seem to get a more uniform and darker reflection onto the floor. By this I mean, white ball reflects much brighter and black ball's reflection just blends with the floor and is almost invisible.
In real life that I tested, reflections are more uniform and darker shade (therefore much more obvious to our eyes) like a silhouette.
I've gotten a more uniform reflection result (now the black ball's reflection is visible) by emitting each ball but it's just too white and I don't want any balls to emit light in final render.
What would be a good workaround this? I want to achieve reflections with a more uniform shade that are visible to eyes despite what the color of the ball may be; so you can think of it like having another shadow in terms of shade, but that behaves like a reflection, not a shadow. It is very hard to explain but I hope someone could guide me in a right direction.. Thank you in advance!
2 REPLIES 2
This is a situation i've found myself in before and i'm not sure I have the answer (look forward to any further responses here), but I suspect it's to do with the IOR of the floor. If you reduce the IOR of the floor material to 0, do you get the reflection you're after?
I've already set IOR to 0 in the scene above.. Raising it just makes them even worse and disappear 😞
