Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
how to fix padding error
1 REPLY 1
lindsay_gomes1
2168 Views, 1 Reply
disp] /Cube: padding is at least 4.56x smaller than it should be! given disp_padding: 0.00100000005, recommended: 0.0050106775
how does one read and fix this error its super confusing I read the displacement shader page but don't understand to much I've been using Arnold for 3 years now and its a shame but I still haven't figured the displacement in Arnold right to get perfect and realistic displacement heights
but I need the best master class please someone
Tags (1)
Labels (1)
1 REPLY 1
It's a warning, not an error. Some times a too-small displacement bounds (aka disp_padding aka Bounds Padding) can cause weird artificats. But other times may not be causing any problems in a scene.
You set the Bounds Padding to the recommended value. Since the value in the CINEMA 4D is in cm, you probably want to multiply the recommended value by 100.
https://docs.arnoldrenderer.com/display/A5AFCUG/Displacement+shaders#Displacementshaders-BoundsPaddi...
https://docs.arnoldrenderer.com/display/A5AFCUG/Displacement+Attributes
// Stephen Blair
// Arnold Renderer Support
Technology Administrators
