How to distribute texture equaly over displaced volume
eddi_fuhrmann
eddi_fuhrmann
bildschirmfoto-2021-01-02-um-183911.pngbildschirmfoto-2021-01-02-um-183815.pngsnapshot-000.jpgHallo.
I have been working around the volume displacement and really like it but i have a problem with the texture distribution on the displaced volumes. on this example i have the feeling that towards the more displaced volume the teture does not tile like in the front of the volume...
sure , the volume is more displaced at the end but the texture is hardly visible...do you have some idea how to distribute it a bit more even? or is the texture not good in this case..
greetings and thanks in advance!
lee_griggs
Did you set the noise.mode -> vector?
Also, make sure the volume_padding on the object is large enough.
Lee Griggs
Arnold rendering specialist
AUTODESK
eddi_fuhrmann
i am using a c4d noise for the displacement. can i set this to vector,too?
in the end i used a uv projection node to distribute the texture correctly. thank you!!
