Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
How to create puddles?
7 REPLIES 7
Message 1 of 8
pygmalionNH76Y
1748 Views, 7 Replies
I'm pretty new to Arnold and really enjoying it so far. There's one thing I'd like to do though and I can't seem to find a tutorial or answer anywhere yet, though I'm sure it's probably a pretty noob question. I would like to have a floor with various random areas on said floor contain wet, reflective puddles. I've tried to do this with the mix shader with a bump map made of noise but can't really get the effect I'm looking for.
Any help would be greatly appreciated!
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
Hi! Maybe this tutorial works great for you:
https://www.youtube.com/watch?v=2DEjSyYfEpE
Message 3 of 8
Thank you, but that's a tutorial for Octane, not Arnold.
Message 4 of 8
Of course but you can translate the same theory with Arnold.
Message 5 of 8
I don't think this is an Arnold thing. I'd approach with geometry. If you created puddle holes, all you would need is a plane object with a water shader on it just under the floor.
Message 6 of 8
Thanks, The Bag, I think I'll approach it that way.
Message 7 of 8
lee_griggs
in reply to: pygmalionNH76Y
The Coat Normal is also ideal for situations like this. A puddle example can be found on the Coat page.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 8 of 8
You can definitely use that octane tutorial linked above and apply it to Arnold. That's what I did and it worked perfectly!
