Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
How to create backlight Mask
9 REPLIES 9
Message 1 of 10
minhtampts
429 Views, 9 Replies
Hi All!
I want create back light Mask same c4d material in arnold, please look the picture.
I want create this video with arnold render
My project in attack file
And I have a problem, when I use Ctrl + darg to copy shader nodes in arnold shader network editor. I always have 2 copied nodes, i don't like it. How to copy only 1?
Thank All!
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
lee_griggs
in reply to: minhtampts
You could just use a mix shader. Connect a ramp to the mix_weight.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 10
minhtampts
Thank Guy!
But how to create mix map? I can't find ramp setting use shadow or highlight as a Map to mix
Message 4 of 10
minhtampts
in reply to: lee_griggs
@lee_griggs
Good morning Bro!
I tried ambient_occlusion, ramp, curvature, facing_ratio,... It not work
I hope some one there can help me!
Message 5 of 10
lee_griggs
If the light isn't moving, you don't need it. You can just eyeball it by positioning the ramp.
Lee Griggs
AUTODESK
Message 6 of 10
lee_griggs
I created a few shaders here: Mix shader, distance shader (with plane), and toon shader. I think the toon shader works best and gives you more control.
Lee Griggs
AUTODESK
Message 7 of 10
minhtampts
@lee_griggs
Thank Bro! I will try it
Message 8 of 10
minhtampts
@lee_griggs
Problem number 2, why i have 2 copies nodes when use Ctrl + drag. How to copy 1, bro?
Message 9 of 10
lee_griggs
Are you selecting one node? It should only duplicate one node.
Information about working with nodes can be found in the bottom half of this page.
Lee Griggs
AUTODESK
Message 10 of 10
peter_horvath
@minhtampts wrote:
@lee_griggs
It's a known issue in the legacy node editor for a while now, as stated in the release notes. Unfortunately it can not be fixed from the plugin. I recommend to use the new Node Material with the builtin node editor.
// Peter Horvath
// C4DtoA developer
