Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
how to automatic render and save Z depth
3 REPLIES 3
gomeslindsay
251 Views, 3 Replies
Hi
I am working on an animation and wanted to know how can I process the Z channel on its on
atm the way I work with it is after the render is done I manually have to add the filter and save each Zdepth frame which is super time consuming when its like 200 frames that I have to render is there a way where it is automatically saved in a folder
Tags (1)
Labels (1)
3 REPLIES 3
Just add a Z AOV ?
// Stephen Blair
// Arnold Renderer Support
I do that but it exports as a regular EXR file without the filter added to it so I have to manually go through each frame and add the filter and then export it and when its like 300 frames that's a lot of work 😕
Go to the AOV tab of the Arnold render settings and add the Z aov to the active AOV list.
It will be written to a multipass exr as a layer.
