Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
How do you add surface imperfections?
5 REPLIES 5
Harris_Majeed
1008 Views, 5 Replies
How do you add surface imperfections like smudges or scratches onto a standard_surface? In my case, I'm trying to add scratches to a shiny metal surface.
Labels (2)
5 REPLIES 5
lee_griggs
in reply to: Harris_Majeed
Are you using the scratches osl shader? If so, there is an example at the bottom here.
Otherwise, it's output -> specular_roughness
Lee Griggs
Arnold rendering specialist
AUTODESK
Harris_Majeed
in reply to: lee_griggs
If I do that, the metal will not have many specular highlights and won't look shiny. How do I preserve the roughness value so that the metal is shiny while also adding scratches using an image? I would not want to use a separate gloss map.
lee_griggs
You can connect the file texture to a range or color_correct shader to control the results in the specular_roughness.
Lee Griggs
AUTODESK
lee_griggs
Can you share some images of what you are getting vs what you want? Here is a working example of a roughness map (MtoA).
Lee Griggs
AUTODESK
lee_griggs
Did you try the scratches osl shader?
Lee Griggs
AUTODESK
Technology Administrators
