Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
How do I know what values are being outputted from a given node?
4 REPLIES 4
238 Views, 4 Replies
I'm having trouble wrapping my head around the shader network because I don't know what's going on behind the scenes. When I use the utility node and set the color mode to Object ID, how do I know what exactly is being outputted? And same for rgb_to_float, how do I find out what value it is outputting so I know how to use it properly? Or am I just thinking about this all wrong?
Labels (1)
4 REPLIES 4
Stephen.Blair
Object ID gives you a color value based on a numeric ID assigned to an Arnold shape node.
The output color from rgb_to_float is determined by the mode (min, max, average, and so on).
min is the minimum of the R, G, and B values
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
I believe you, but how do you know this? Where can I find deeper information like this? Their manual hasn't proven very useful. And I'm sorry, but still don't understand the rgb_to_float. This sounds like it is taking in three values (R, G and B) and spitting out a floating number (2.35, 1.2 etc.) How do I know or see that number? Is there some console that shows the passing values?
Stephen.Blair
RGB is three values.
If mode is max, then rgb_to_float takes the largest value of the three, and outputs that as a float.
You cannot see the exact output in a console. Logging values for every shading point would be very expensive.
You can visualize the output like this:
// Stephen Blair
Thank you, however, I do disagree it would be expensive. A simple number representing a nodes current value at the bottom of the node would do a lot for understanding how values are moved and changed around. I hate guessing or assuming what is happening to the traveling values, or having to plug into beauty each step to ensure I'm getting what I need.
