Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
How can I use Houdini cd attribute data in Arnold cinema 4d?
4 REPLIES 4
abenezer_aklilu
392 Views, 4 Replies
I try to use Houdini cd attribute in the user_data_rgb but it's given me black color1642421484111.png
Tags (1)
Labels (1)
4 REPLIES 4
What are you using it with in C4D? Anything in the log file?
Lee Griggs
Arnold rendering specialist
AUTODESK
Is that a default ramp_rgb node? If so, set the type to Custom
Otherwise, please first try the user data as the standard_surface base color.
// Stephen Blair
// Arnold Renderer Support
Okay thanks it's work, but how can I use alembic particle cd attribute from Houdini in cinema 4d
I exported particle from Houdini with cd attribute but I don't know how to use it in cinema 4d
Arnold can you help me out
You use the user data shader.
What's not working?
// Stephen Blair
