Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
How can I apply shader with textures to complex object properly?
4 REPLIES 4
millenniumsevenYHVL8
450 Views, 4 Replies
Since I don't know how to make models in C4d, I've always import models from Rhino or Fusion 360 for rendering. And when I try to apply some textured shaders, they always rendered like they're pulled up somewhere or some point like the images below.
I think I have to do something with UV mapping or polygon edit, but those techniques are kind of complicated for a beginner :p. Can anybody tell me what am i supposed to do to apply shaders looks uniform or not distorted like this image ?
Tags (3)
Labels (3)
4 REPLIES 4
probably nothing can save you at some point from properly uv map your stuff .. but for the while you may try with an aiTriplanar texture node
@Max Tarpini
thanks for the advice. I don't know what that is, but i'll try.
It worked! I should check it deeper to apply with bump map or displacement. much appreciated.
https://docs.arnoldrenderer.com/display/A5AFCUG/Triplanar
Lee Griggs
Arnold rendering specialist
AUTODESK
