Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Hi, I am having trouble removing some grain from a highlighted portion of a model, that is a bit out of focus, using DOF, my texture has SSS, can someone please tell me, is this a AA issue,?, ray sample,? any advice is appreciated, thx
7 REPLIES 7
Message 1 of 8
cpz
216 Views, 7 Replies
7 REPLIES 7
Message 2 of 8
lee_griggs
in reply to: cpz
An image would be really useful. If it is in DOF, then yes its probably an AA issue. To check, you could try rendering out AOVs to help identify where the noise is coming from.
More information about removing noise in C4DtoA can be found here.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 8
cpz
in reply to: cpz
Hi, thank you, apologizes for not providing a screen shot!-I figured it was the AA, will do AOV check, but I did find out a specific light was the culprit, the focal light, any revelations would be greatly appreciated, Best, Craigscreen-shot-2018-01-17-at-92053-am.pngscreen-shot-2018-01-17-at-91939-am.pngscreen-shot-2018-01-17-at-91231-am.png
Message 4 of 8
cpz
in reply to: cpz
Hi again, I am trying, unsuccessfully to download a sample file, here is the address, https://support.solidangle.com/display/A5AFCUG/AOV+Object+ID#, I've tried, Safari, Google Chrome, Firefox, none work, perhaps you make a suggestion for me, ? thank you
Message 5 of 8
Stephen.Blair
in reply to: cpz
The link is just the link to the page.
Click Tools > Attachments. You'll see the c4d scene file in the list.
// Stephen Blair
// Arnold Renderer Support
Message 6 of 8
cpz
in reply to: cpz
Thank you, but all I see is the c4d file, AOV write, which I was able to download, I was referring to AOV object ID, or are they the same?-I really do appreciate all of your sage advice, a wonderful asset here!-;)
Message 7 of 8
Stephen.Blair
in reply to: cpz
Yes, that's all it is. You use the aov_write_rgb to write out an object ID aov, where the "id" is a unique color provided by the utility shader
// Stephen Blair
Message 8 of 8
cpz
in reply to: cpz
Thank you, once again, Stephen, Best, CZ
