Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Hair Arnold Tag Export UVs for color, use texture for Opacity
2 REPLIES 2
esli.becerra
126 Views, 2 Replies
I am trying to make a sort of impressionist painting style set up by using C4D hair. (mainly because I can brush it unlike Mo graph where you cant. I want the material to to pick up Objects Uvs color and project a paint brush stroke texture across the hair plane to attach to the materials Opacity.
Is there a way to set UVs to ignore attribute tag export UVs for some textures?
@teddude75
2 REPLIES 2
You can read the bu, bv coordinates via a state_float shaders and connect them to image.uvcoord, where you want the original (Export UVs unchecked) uvs.
// Peter Horvath
// C4DtoA developer
esli.becerra
in reply to: esli.becerra
Thank you so much!!!!!!! That totally worked!!!!!
