GPU rendering transparent material error
RaynerR
RaynerR
When rendering transparent material highlights in GPU mode, unexplained black spots may appear.Normal rendering in CPU mode.
GPU:
CPU:
lee_griggs
What are the sampling settings for each?
How many light samples?
Can you post a scene link here?
Lee Griggs
Arnold rendering specialist
AUTODESK
RaynerR
Thank you for your reply. This is a simple scene file
lee_griggs
Thanks for the scene. This is a known issue with glass and GPU.
Lee Griggs
AUTODESK
thiago.ize
This is likely due to GPU not allowing for ray splitting so sometimes an AA sample will reflect off the glass and other times it will refract and go through the glass. If you increase AA the image should eventually look correct.
RaynerR
Thank you for your answer. Adding camera AA can make it correct, but using this method in the project would increase rendering time significantly,thanks.
