GPU rendering error
GPU rendering error
1581825872
Observer Observer
GPU rendering error
1581825872
Observer
Observer
I made an error when using GPU rendering, the following is my configuration information, may I ask what the problem is, there is no problem using CPU, except slow...
lee_griggs
We are aware of this issue. It will be fixed in a future release. Thank you for the feedback.
Lee Griggs
Arnold rendering specialist
AUTODESK
Observer
Observer
You're welcome. Hope it gets better
jollandesingfolower
Hi. I couldn't find more posts with the error
(CUDA Error Code 700 - 716)
That's why I'm writing this post.
I faced with this problem that after the update 4.6.7 began to appear such an error, later came out the update 4.6.7.1 in the list of which was indicated that the problem is sort of solved but it is not clear whether completely or not but after tests with a simple scene the problem did not disappear by the way this scene in which I conducted tests I built in version 4.6.6 and in that version it is quietly rendered through the GPU and does not give this error.
I will also attach the files of the scene
If you need information about my hardware, here it is
CPU : i7-8700
RAM : 16gb
GPU : GTX 1060 6gb
driver : 551.23
jollandesingfolower
I also forgot to write that before opening this scene new projects are rendered correctly, but in the case of this scene after opening it and trying to render through IPR there is an error and subsequently new and old scenes also begin to display an error after restarting Cinema 4D 2024.
the error disappears until I open the scene that causes it.
