Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
GPU render warning
2 REPLIES 2
tonybridgeQXEP8
117 Views, 2 Replies
GPU render warning
I´m learning arnold and get this message in the IPR window, does anyone know how to fix this: [c4dtoa] 00:00:00 4600MB WARNING | [gpu] Empirical SSS unsupported on GPU, switching to randomwalk in shader /Backdrop|standard_converted. ?
I´m using the last version of Arnold and C4d 2023.2.2
Thanks guys!
2 REPLIES 2
Diffusion SSS type is not supported on GPU, hence the warning. The warning is thrown even if SSS is disabled in the standard_surface shader, which might be confusing. You can switch to randomwalk if you go to Subsurface settings of the standard_surface shader.
// Peter Horvath
// C4DtoA developer
Thanks i will try that.
