GPU memory not utilizing
Hi there,
Arnold For Cinema 4D, C4dtoA Version - 3.3.6
GPU - Zotac gaming Nvidia RTX 3090(Trinity 24GB Graphic Card)
Ram - 64GB, (DDR5)
Nvidia graphic card driver version - 461.92
Arnold renderer was not pulling over 7GB to 8GB, My actual VRAM memory 24GB
here the render screen shots:
Arnold render settings :
Resolution - 4096 x 4096
Camera AA sampling - 10 (max)
Adaptive sampling enabled to - 20 ,0.005
materials -PBR, Default
I don't know why happening like this, if anybody solve this
Please do the needful
Thanks in advance !.
Stephen.Blair
How do we know that more memory was needed?
Can you post an Arnold log?
// Stephen Blair
// Arnold Renderer Support
HI Stephen,
I also checked in another PC ..its working Well
alternative pc is using more than 18GB of 24GB graphic card
Here the render Log file
arnoldwatch.txt
Stephen.Blair
Do you have an Arnold log from that machine too?
// Stephen Blair
thiago.ize
00:00:37  7055MB    | peak CPU memory used     7184.30MB
00:00:37  7055MB    | at startup               5773.38MB
Shows that CPU used 7.2GB (with most of that, 5.7GB, coming from C4D and not arnold).
00:00:37  7055MB    | peak GPU memory consumed 1061.56M
Shows that GPU used a peak of 1GB.
00:00:00  5773MB    |  GPU 0: NVIDIA GeForce RTX 3090 @ 1695MHz (compute 8.6) with 24576MB (19558MB available) (NVLink:
Says that before Arnold even started, 24576MB-19558MB, which is 5GB, of GPU memory was already being used up by C4D, Windows, and other applications. So when you see 7GB in GPU-z, about 1GB comes from arnold (maybe 2GB if there's a temporary peak we didn't capture) and the rest is non-arnold applications that also use the GPU.
Everything is behaving as intended.
