Getting rid of noise from indirect diffuse
elik
elik
I am trying to render an exhibit concept that uses a room with a transparent cylinder in the center and a point light the moves through it vertically to cast shadows on the walls. I keep getting a lot of noise in the indirect diffuse no matter what I tweak, from light samples to Arnold settings. How do I get rid of the noise?
mckenzie2VER2
Do you have an example scene to look at?
lee_griggs
Hi, can you post some images with render settings so that we can get a better idea of where the noise is coming from? If it is indirect_diffuse noise then increasing the number of diffuse samples will reduce the noise. Be careful as increasing this value can increase render times substantially. There are tutorials on removing noise here:
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_cinema_4d_ci_Tutorials_ci_Removing_Noise_h...
Also, if you are not already using them, there are the denoising imagers and the Arnold Denoiser.
Lee Griggs
Arnold rendering specialist
AUTODESK
mckenzie2VER2
In my tests I've found that having higher AA samples, low Diffuse and higher strength settings with Noice works well on interiors. I'm on a Mac so can't use Optix.
For example:
2000x2000px scene
2 Lights (1 Quad 4 Samples, 1 Direct 3 Samples)
Settings #1
AA 3
Diffuse 4
Diffuse Ray Depth 6
Adaptive Samples Max 6
Threshold 0.35
Noice Variance: 0.25
Search Radius: 9
Render Time: 1h:49m
Settings #2
AA 6
Diffuse 2
Diffuse Ray 6
No adaptive
Noice Variance: 0.6
Search Radius 16
Render time: 54 minutes
Going the higher AA and low diffuse route nearly halved the render time. I think it works better this way because Noice has more AA samples to work with so you don't get the blotchy denoised look. Lowering the AA speeds up the render but the de-noisinig isn't good, very patchy. Increasing the Diffuse skyrockets the render time.
elik
Many thanks. I'll try these settings. One thing that seemed to help a lot was turning on and reducing the Diffuse Clamping between 1-4
