Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Getting an error when using greyscale gorilla light kit pro
2 REPLIES 2
1070 Views, 2 Replies
I just installed lightkit pro from greyscalegorilla in C4D r19. When I used one of their studios it renders in C4ds renderer but not in Arnolds IPR window. I checked the console script and it seems the issue is with the lights. this is one of the errors I got "WARNING: cannot declare constant INT light_Falloff on...-name already in use
2 REPLIES 2
peter.horvath6V6K3
I'm not sure that warning is related. The plugin tries to declare user parameters in each IPR update when the light changes, and they are already declared, that's why this warning shows up.
I forwarded the issue to the guys at Greyscalegorilla, since they know more about this toolkit.
chadGE3G6
Hi Devin, Light Kit Pro is only supported by Standard and Physical renderers. It will not work in any other renderer.
