Frequent crashing during rendering
Message 1 of 42
Hello guys,
I have a big scene that experiences frequent rendering crashing, would you please have a look at bug report what I may do to make Cinema more stabel?
_BugReport.txt
Replies (41)
Message 2 of 42
Stephen.Blair
Maybe it is texture related.
        Call_Stack_Thread_123145790861312
            libai.dylib:    0x11fcf391b (SP: 0x70001d1e6810, PC: 0x11fcf391b)
            libai.dylib:    0x11fdc0202 (SP: 0x70001d1e6af0, PC: 0x11fdc0202)
            libai.dylib:    0x11fdbee88 (SP: 0x70001d1e6c50, PC: 0x11fdbee88)
            libai.dylib:    0x11fdbd5a7 (SP: 0x70001d1e6d60, PC: 0x11fdbd5a7)
            libai.dylib:    _AiTextureHandleAccess + 0x109f (SP: 0x121c86df0, PC: 0x1209e8cff)
Any chance you could post a detailed Arnold log?https://docs.arnoldrenderer.com/display/A5AFCUG/Log
As a test: If you ignore textures, do you still crash?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 42
Hello Stephen,
What do you mean ignoring textures? Do you mean "abort on error" option?
Daniel
Arnold Log.txt
Message 4 of 42
this could be causing the crashes, but no idea why, does arnold have pronlem with tif format?
00:00:32 16808MB ERROR| [c4dtoa] Failed to generate 66 TX files:
00:00:32 16808MB ERROR| [c4dtoa] /Library/Application Support/Laubwerk/Plants/Howea_forsteriana/textures/Howea_forsteriana_lf_03_co.tif
Message 5 of 42
peter.horvath6V6K3
You'll find the Ignore textures option in the render settings. You can also try to disable auto tx, not sure it helps though.
Can you send us one of the failing textures?
Message 6 of 42
https://we.tl/t-aFBKdCGwgh
I uploaded one of the TIF 's, I suspect they are the bad apples.
Message 7 of 42
peter.horvath6V6K3
This texture works fine for me, the tx file is generated properly. Which version of C4DtoA do you use? I tried the latest 3.0.3.
Message 8 of 42
I use latest version too, I think crashes were caused by too many instances made by plugin Surface spread 2. After reducing number of them, Arnold stoped crashing.
Error reports such as:"ERROR: Could not open "/Library/Application Support/Laubwerk/Plants/Howea_forsteriana/textures/Howea_forsteriana_lf_03_co.96a628fd.temp.tx"" still puzzle me however.
Anyway let's call it as solved
Message 9 of 42
**UPDATE**
Opened the .jpg in Affinity and changed color profile from sRGB IESC61966-2.1 to generic RGB. now error is not appearing.
**UPDATE**
00:00:19 7248MB ERROR| [texturesys] /Inox|oaktramonto597267-edit_2: /Volumes/Samsung_X5/materials/Metal/Smooth Metal/Textures/Smooth Metal 3/Metal_009_NRM_6K.tx
00:00:23 7250MB ERROR| signal caught: SIGFPE -- Floating point exception
Hi guys, I get frequent crashes during rendering. I pasted report from Log. It points to this texture which seem to be fine. I don't see an obvious issue there.
Message 10 of 42
Hmm, errors have returned, same textures:
C4DtoA | 00:00:14 9563MB ERROR| [texturesys] /Smooth_Metal_Aluminium_Dark|oaktramonto597267-edit_2: /Volumes/Samsung_X5/materials/Metal/Smooth Metal/Textures/Smooth Metal 3/Metal_009_NRM_6K.tx
C4DtoA | 00:00:14 9563MB ERROR| [texturesys] /Smooth_Metal_Aluminium_Dark|oaktramonto597267-edit: unspecified OIIO error (filename = "Metal_009_COL_6K.tx")
Message 11 of 42
Now it crashes but no reference to texture, only this message I don't understand:
00:00:32 11619MB ERROR| signal caught: SIGFPE -- Floating point exception
Message 12 of 42
Stephen.Blair
That's a file system error. When a tx file is created, everything is written to a temp.tx file, and when the conversion is finished, the temp.tx is renamed to .tx
// Stephen Blair
Message 13 of 42
Resaving problematic textures as other file formats made these error messages go away, thanks for getting back to me
Message 14 of 42
Stephen.Blair
It's a pretty generic message. It could be many things.
It could be a bug, but what triggers the bug?
All these texture errors are a concern...did you try with Ignore Textures, as a test?
// Stephen Blair
Message 15 of 42
Since it crashes on occasion I always save the scene and take a risk of crash. I have tight deadline, I cannot afford extensive testing without textures. As for right now all errors are gone. Seems like Arnold is picky what textures it accepts.
Message 16 of 42
What could this error mean Stephen?
00:00:21 9307MB ERROR| [texturesys] /Cow_Skin|image: Not a TIFF or MDI file, bad magic number 12150 (0x2f76) (filename = "sksprql_4K_Normal.tx")
00:00:21 9307MB ERROR| [texturesys] /Cow_Skin|image_3: Not a TIFF or MDI file, bad magic number 12150 (0x2f76) (filename = "sksprql_4K_Albedo.tx")
Message 17 of 42
I checked ignore textures and crashing stoppet. As soon as I turned them back on c4d crashed. So something about textures I guess:
Arnold Log:
00:00:13 7647MB WARNING| [AiMakeTx] OpenEXR "dwaa" compression has a bug for monochrome images, using "zip" instead
"/Cams___Lights/Cam_C_Dolomiten_Suite/Plane_6", but there is no opacity metadata for some of its shaders
00:00:15 7680MB ERROR| signal caught: SIGABRT -- Abnormal process abort
Message 18 of 42
thiago.ize
This suggests your .tx file might be corrupted.
Are you getting the same error message each time or is it different? If it's random seeming, with it sometimes working, sometimes not, maybe this could be a symptom of bad hardware? If it's the same, can you supply a broken .tx file for us to look at?
Message 19 of 42
Hello Thiago,
I have resaved jpg as tiff and error messages regarding .tx have dissappeard. Arnold still crashes thought, get follwing errors:
Message 20 of 42
Stephen.Blair
Those are just warnings/info messages. The first one comes from the auto-tx, where we have to use a different compression to avoid a bug in OpenEXR.
The second is just telling you that some object has Opaque off, even though none of its shaders are making it transparent.
The ERROR is a generic crash message, so we still don't know what's happening to cause the crash.
// Stephen Blair
