Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Freeze IPR render AiNodeDestroy
10 REPLIES 10
Message 1 of 11
JHåland
445 Views, 10 Replies
Hi, think I have a problem with AiNodeDestory. It's comes from Object masks I've made. But I really want to use those masks, and can't find a solution for it.
The message in console is:
cannot destroy node "/Name/Name_122" while rendering; ignoring call to AiNodeDestroy
Tags (3)
Labels (3)
10 REPLIES 10
Message 2 of 11
Stephen.Blair
in reply to: JHåland
What's the problem? Is it "IPR freezes when you do something that triggers a call to AiNodeDestroy" ?
Can you provide a scene that reproduces the problem?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 11
JHåland
in reply to: Stephen.Blair
I can see if I can make a simple version
Message 4 of 11
JHåland
hmm, sorry for not coming back to you earlier, life happen. While trying to create a simple version I think I stumbled upon the problem. I think it is a Bevel deformer that crashed the scene. Really strange. I guess I changed that a bit, didn't more about it, and then tried to add more details in the material that is connected to the mesh. I can't share the file sadly, and I can't recreate the problem on my Mac. But seems to be the problem if I go back to an old scene with the bevel deformer still on.
Message 5 of 11
JHåland
Hi again, it seemed this is a occurring problem when I use deformers.
I also use ACES. I got the same problem in another scene and this I can share.
Download here: https://www.dropbox.com/s/seeatp7g3kcbuxc/arnold%20crash.c4d?dl=0
Open file
Start the IPR
Open the material and try to do something in the shader network, like change the base weight, and it freezes.
Turn of IPR and the deformer and it works as expected.
I use Windows 10, Cinema 4D 20.059 on a AMD Ryzen Threadripper 3970X
Message 6 of 11
Thanks for the scene, unfortunately I haven't been able to reproduce it so far.
Does it hang or crash for you all the time or randomly? There are no textures in the scene, right? (I just fixed a hang caused by textures in C4DtoA 3.3.3) What's your C4DtoA version, btw?
I'm also noticing that you have an Arnold denoiser imager in the scene. I wonder if removing the denoiser makes any difference.
Message 7 of 11
JHåland
It crashes consequential if the deformer is activated in the scene.
I’ve simplified the scene as mush as possible to check if the problem still happens.
I have tried to turn of the imager and it still happens. I can try to update to 3.3.3
Message 8 of 11
JHåland
hey! seems 3.3.3 helped! I’ll test different scenes that this has occurred
Message 9 of 11
Glad to hear that! Just let me know if you still find any issues in 3.3.3.
Message 10 of 11
Jupp seem to have solved the problem in both scenes 🙂 Have a good weekend
Message 11 of 11
Awesome, thank you!
Technology Administrators
