Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Found some problems
1 REPLY 1
140 Views, 1 Reply
Found some problems
1.The original function is missing.The latest version does not work.
2.It is not smooth when adjusting the roughness and color correction nodes, and the experience of the latest version is not as good as the version before 4.3.0
I found these problems temporarily,Maybe I used it in the wrong way.
All tests are based on Cinema 4D 2023.
Everything is normal in cinema 4D R26.
1 REPLY 1
peter_horvath
in reply to: 895793442
As far as I know, this feature was removed by Maxon in Cinema 4D 2023, because they did not feel the implementation was good enough. Hopefully it will be back in a future version.
2. It is not smooth when adjusting the roughness and color correction nodes, and the experience of the latest version is not as good as the version before 4.3.0
I guess it depends on the scale you're working with in your scene. We found that this default value suits most people better. You can always add an Arnold tag and change the height to 100 cm or whatever fits your scene the best, or adjust the scale in the displacement shader.
// Peter Horvath
// C4DtoA developer
