fbx render time
fbx render time
gomeslindsay
Message 1 of 16
fbx render time
gomeslindsay
hey,
I recently animated a charter in daz studio and imported the fbx file to c4d but for some reason it takes forever to render even 5% of it is there any way of speeding the render process
Replies (15)
Message 2 of 16
Stephen.Blair
Impossible to say, not without more information. Can you post an Arnold (verbosity level Info) ?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 16
lee_griggs
What are the texture file sizes from Daz Studio?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 4 of 16
gomeslindsay
@Lee Griggs I am using a 2k texture that I made from substance painter
I have a MacBook Pro 32gb ram 8core I9 and a radeon pro 560x
its a taking a min of 2hr 45 min to render a single frame which is impossible to work
with since I have about 80 frame to render
Message 5 of 16
lee_griggs
What sampling settings are you using? Can you post UI screengrabs, please too to help us identify the issue?
Lee Griggs
AUTODESK
Message 6 of 16
gomeslindsay
@ as you can see as well my scene is very simple8215-screen-shot-2020-09-21-at-14826-pm.png
Message 7 of 16
lee_griggs
How many light samples? Why 3 transmission samples? There is no glass in the scene? Camera (AA): 5 should be enough as I don't see any textures.
Lee Griggs
AUTODESK
Message 8 of 16
lee_griggs
If that doesn't work, can you post the scene/textures somewhere?
Lee Griggs
AUTODESK
Message 9 of 16
gomeslindsay
so i have 2 light sources both samples 3 and i do have a pores texture which is very important since I finally learnt how to sort of perfect it which is visible when my camera is zoomed in
Message 10 of 16
thiago.ize
As Stephen said, an arnold log would let us see where the time is going. Instructions on how to generate a log file are on the right side of this page.
Message 11 of 16
gomeslindsay
can you post the scene/textures somewhere? sorry I did not understand
Message 12 of 16
Stephen.Blair
Upload the scene file and any required textures to a file sharing service, like Dropbox or Google Drive or wetransfer.
// Stephen Blair
Message 13 of 16
gomeslindsay
Message 14 of 16
thiago.ize
Thanks, but the logs are missing the stats part. You need to let the render finish for those to be printed out. How about rendering only a 100x100 pixel region so it goes more quickly and gives us some stats?
Also, you're running a version of Arnold from almost two years ago! I highly suggest upgrading.
Message 16 of 16
lee_griggs
I changed the mesh lights to quad lights. They will render more efficiently.
I stripped out all of the textures (why are there so many?). It is a shame that the body has been split up to so many textures for each body part. Can you export just one set of textures for the entire body from Daz? If not, strip out the textures that you don't need and maybe shrink the size of them and convert them to .jpg might speed up the conversion process.
Rendering without textures took 2 seconds.
Scene here. Password: arnold
Lee Griggs
AUTODESK
