Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
FBX maps to standard surface
1 REPLY 1
419 Views, 1 Reply
Hello, I received an FBX model by a client with some maps. I'm a little confuse with the naming convention of the maps and where they go into the standard surface node.
mat0_c -> color that goes into color base ?
mat0_n -> normal that goes into normal geometry ?
mat0_r -> reflection that goes into metalness ?
mat0_g -> glossiness that goes into roughness specular ?
mat0_s -> specular that goes into weight specular?
Thank you for any insights.
Labels (3)
1 REPLY 1
peter.horvath6V6K3
I don't know much about FBX but your suggestion sounds good to me. For the normal use a normal_map shader, as described here.
