Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Everything turns green C4D
6 REPLIES 6
957 Views, 6 Replies
I have c4D R 20 and everthing looks great in the IPR window, but when I render it, it renders in full color and then changes to a green hue at the last second of the render. Anyone have a solution?
Tags (2)
Labels (2)
6 REPLIES 6
peter.horvath6V6K3
Sounds like you have some effect added to the render or the filter enabled in the Picture Viewer. Does this happen only with Arnold? Do you see the same problem in a new clean scene?
I am not using any effects, I do not have filters enabled. It only happens with Arnold and it happens with a new clean scene. I have tried every render setting, I have reinstalled both c4d and Arnold. Please help, I have tried everything. Thanks
Sorry figured it out in the Stereoscopic calculating. Thanks!
peter.horvath6V6K3
I'm glad you could find it. Could you tell me which setting caused the issue. I wonder it may be a bug if it affected only Arnold. Or some setting which should be skipped.
It was in the Arnold render settings under Stereoscopic, Calculate Stereoscopic Images: "Merged Stereoscopic Image" was selected.
peter.horvath6V6K3
Right, that makes sense and it's not Arnold specific then. Stereo camera support was added in C4DtoA 2.4.5, so if you have an older scene where the Stereoscopic effect is enabled then it may render differently now depending on the settings.
Thanks for the feedback, much appreciated.
Technology Administrators
