Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Engraved stone material?
1 REPLY 1
231 Views, 1 Reply
Very new to arnold and nodes. I am trying to make a material where there is stone with egyptian hierglyphs engraved into the stone.I do not know how to make sandstone or limestone from scratch and I do not know how to add the glyphs on top afterward. Is there layering involved? displacement? I am not sure where to start. There aren't a lot of sources online about this specific thing. Any tips would be very helpful. Here is a reference and here is the image that I was going to use as a part of a pbr material. Thanks!
Labels (4)
1 REPLY 1
lee_griggs
From the user guide:
How to setup displacement.
Remember to increase subdivision_iterations for the object that you are displacing.
Then you could use rock or sandstone texture for the color and rock bump texture. You could even try doing this procedurally using noise shaders when you feel more comfortable.
Hope that helps!
Learning Resources.
Lee Griggs
Arnold rendering specialist
AUTODESK
Technology Administrators
