Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Emitting particels from a circular ramp in x particels
4 REPLIES 4
eddi_fuhrmann
224 Views, 4 Replies
screenshot-2021-04-25-112523.pngscreenshot-2021-04-25-112750.pngHello.
i have a plane with an arnold texture (circular ramp in black and white) and want to emit the particels using the object parameter/ texture tag in the xp emitter. so i put an arnold tag on the emitter and set everything up but it won´t work with the the arnold material. when i put a normal c4d material on it everything works fine...i know you need to use a user_data_rgb node for the color input, right? so xparticels uses the information of the material.. i put the node in the base color slot and the ramp into the emission color slot put it won´t work no matter what i try..so i have the following questions..
-do i have to put a material on the emitter, too? or is it okay only using the texture tag of the planes material. because i want to use the color values of the plane...screenshot-2021-04-25-112657.png
-do i have to put the user_data_rgb node always in the base color slot and the color input in the emission color or is there a way to use the normal base color with the user_data_node (tried a layer node but it did not work)
-can the xparticels material be of any use here?
Labels (3)
4 REPLIES 4
The Arnold Material is a custom material, basically it's just a gui representation of the Arnold shader node network, and X-Particles has no knowledge of it. So using an Arnold material to emit particles won't work, you can use only a standard C4D material (or whatever material XP can understand.)
okay thank you so far.
in this tutorial
https://www.youtube.com/watch?v=WGUggSQaBFs
at minute 38 he blends together two materials which are defined by a ramp in x particels-the older the particels get the color changes from white to black and he uses the color values for the shading in the material...kind of like with a vertex map...is there a possibility to do the same in arnold...i guess not but i just wanted to ask...as always thanks for the help!
I'm afraid there's no equivalent of the Point Density Texture node in Arnold. If you could generate a vertex map in the mesher, that could work.
hm okay i have tried to generate a vertex map for the vdb masher but i think it does not work...thanks for your help anyway!
