Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
EmberGen VDB Problem with Arnold Volume
2 REPLIES 2
seijeto
97 Views, 2 Replies
Hello!!
Im trying to use EmberGen with Arnold Render - Arnold Volume but is not seem to working.
First i have create a test simulation in EmberGen
and export to VDB
Next i create Arnold Volume and import the first vdb file (totally in this example created 200 vdb files)
+Arnold sky creation and nothing working...
In Console i can see that:
[c4dtoa] 00:00:00 2170MB WARNING | /Arnold_Volume: shape has empty bounding box: (inf inf inf x -inf -inf -inf)
So whats the problem, i used the EmberGen and not some whatever VDB file, is possible arnold wont working with EmberGen?
Thank you very much!
2 REPLIES 2
Stephen.Blair
in reply to: seijeto
That's just a warning, not an error, and means that Arnold is going to have to figure out the bounds itself. Which is not optimal.
Can you get a detailed log with more than just the warnings?
// Stephen Blair
// Arnold Renderer Support
seijeto
Thanks for your answer, the solution for this problem is to Update EmberGen to to latest version, there arnold should work correctly!!
