Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Drag and drop texture to node editor hangs
5 REPLIES 5
jdm_007
320 Views, 5 Replies
On MacOS (Ventura) and M1 Ultra Studio with Arnold C4DtoA 4.5.0 [5d5178cf], when I drag and drop a texture to the new node editor, I get a beach ball and C4D hangs. I need to kill the C4D process.
To reproduce:
- start with a fresh instance of C4D 2023.1
- switch to Arnold
- Create a node material
- Drag and drop a texture from finder to the node editor.
- You'll get the beachball. I've waited several minutes but ended up having to kill the process.
Thank you
5 REPLIES 5
jdm_007
in reply to: jdm_007
Just a quick reply that I also tested on Windows and I have the same problem. The problem does not happen when Redshift is the renderer so I assume it might be an Arnold cross-platform bug.
peter_horvath
Yes, I can reproduce it in Cinema 4D 2023.1, works fine in 2023.0. I will investigate what has been changed between those two versions. Thanks for reporting the issue.
// Peter Horvath
// C4DtoA developer
peter_horvath
Should be fixed now in C4DtoA 4.5.0.1.
// Peter Horvath
// C4DtoA developer
whelectric
Hi dear
How is the performance of Arnold on M1 ultra studio if compare to Intel / AMD CPU?
peter_horvath
in reply to: whelectric
@whelectric wrote:
Hi dear
There are some test results in the Release Notes, comparing native and Rosetta emulation: https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_core_7140_html
// Peter Horvath
// C4DtoA developer
