Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
DOF on camera causing constant crashing
4 REPLIES 4
Randy_Mills1
1991 Views, 4 Replies
I have a fairly heavy interior scene that is constantly crashing on render when DOF is enabled on my Arnold camera. The weird thing is that if I disable the DOF and render, it will render fine, then when I enable DOF again it will render one frame and then crash on the next frame. Any idea why this may be happening? If all else fails I'll use Z-Depth pass for DOF but I'd rather use the camera if possible. Using the latest C4DtoA (4.0.2) and R25 - CPU render
Labels (3)
4 REPLIES 4
Hard to say what's the problem. DOF itself is just kinda randomizing the rays coming from the camera. And I guess you've increased the AA samples to get rid of noise?
Are you running out of memory? What's the Arnold log say? (you can log to file, so the log is available after a crash).
// Stephen Blair
// Arnold Renderer Support
Randy_Mills1
in reply to: Randy_Mills1
Lowered the AA samples to see if that helps. Rendering out a version now with DOF enabled and will log to file to see if that gives any clues. Thanks for the response @Stephen Blair appreciate the help.
Randy_Mills1
@Stephen Blair Lowered Camera AA to 4 and lowered the rest of my settings as well as set up the imager denoiser. Failed on render overnight. Here is the log:
00:00:00 6617MB | log started Tue Jan 4 23:52:04 2022
00:00:00 6617MB | Arnold 7.0.0.1 [5e3b4fd3] windows clang-10.0.1 oiio-2.3.2 osl-1.12.0 vdb-7.1.1 clm-2.0.0.235 rlm-14.1.3 optix-6.6.0 2021/11/18 13:08:38
00:00:00 6617MB | running on DESKTOP-A13003R, pid=24720
00:00:00 6617MB | 1 x AMD Ryzen Threadripper 3970X 32-Core Processor (32 cores, 64 logical) with 130965MB
00:00:00 6617MB | NVIDIA driver version 472.84 (Optix 60801)
00:00:00 6617MB | GPU 0: NVIDIA GeForce RTX 3090 @ 1695MHz (compute 8.6) with 24576MB (21944MB available) (NVLink:0)
00:00:00 6617MB | Windows 10 (version 10.0, build 19044)
00:00:00 6617MB | soft limit for open files is set at 2048
00:00:00 6617MB |
00:00:00 6636MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:00 6636MB | loading plugins from C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\plugins ...
00:00:00 6636MB | alembic_proc.dll: alembic uses Arnold 7.0.0.1
00:00:00 6636MB | cryptomatte.dll: cryptomatte uses Arnold 7.0.0.1
00:00:00 6637MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.0.0.1
00:00:00 6637MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.0.0.1
00:00:00 6696MB | usd_proc.dll: usd uses Arnold 7.0.0.1
00:00:00 6696MB | loaded 5 plugins from 3 lib(s) in 0:00.09
00:00:00 6696MB | loading plugins from C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\procedurals ...
00:00:00 6696MB | volume_tfd.dll: volume_tfd uses Arnold 7.0.0.1
00:00:00 6696MB | volume_voxel_field.dll: volume_voxel_field uses Arnold 7.0.0.1
00:00:00 6696MB | loaded 2 plugins from 2 lib(s) in 0:00.00
00:00:00 6696MB | loading plugins from C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\shaders ...
00:00:00 6696MB | c4dtoa_shaders.dll: mesh_light_material uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: normal_displacement uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: vector_displacement uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: c4d_vertex_map uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: xparticles uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: image_plane uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: layer_color uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: layer uses Arnold 7.0.0.1
00:00:00 6696MB | c4dtoa_shaders.dll: xp_gaseous uses Arnold 7.0.0.1
00:00:00 6696MB | loaded 9 plugins from 1 lib(s) in 0:00.00
00:00:00 6696MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:00 6712MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:00 6971MB | [color_manager_ocio] using config file C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:00 6972MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:00 6972MB | [color_manager_ocio] using config file C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:11 7091MB | [color_manager_ocio] default ocio.config found in C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:18 7126MB |
00:00:18 7126MB | -----------------------------------------------------------------------------------
00:00:18 7126MB | scene creation time 0:11.36 machine utilization (0.00%)
00:00:18 7126MB | unaccounted 0:11.36
00:00:18 7126MB | top session self-times by category
00:00:18 7126MB | top session self-times by node
00:00:18 7126MB | peak CPU memory used 7153.54MB
00:00:18 7126MB | at startup 6617.61MB
00:00:18 7126MB | node overhead 0.00MB
00:00:18 7126MB | strings 24.25MB
00:00:18 7126MB | unaccounted 511.68MB
00:00:18 7126MB | geometry (% hit ) (instances) ( init mem, final mem)
00:00:18 7126MB | lists 1 ( 0.0%) ( 0) ( 0.00, 0.00)
00:00:18 7126MB | performance warnings:
00:00:18 7126MB WARNING | Scene creation was a significant amount of total time (100%). Consider optimizing this process first.
00:00:18 7126MB |
00:00:18 7126MB | releasing resources
00:00:19 7115MB | [color_manager_ocio] using config file C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:19 7131MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Garota_Park.tx"
00:00:19 7191MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\GSG_SI_Smudges_36.tx"
00:00:19 7468MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\photo_backdrop_01.tx"
00:00:19 7384MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Einstein_BrandMark.tx"
00:00:19 7413MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\53419_3_Scattering.tx"
00:00:19 7418MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\53419_3_Scattering_color.tx"
00:00:19 7426MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Einstein_UI.tx"
00:00:19 7469MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\DH_Logo_PadPrint.tx"
00:00:19 7482MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\FlexceraSmile_hero.tx"
00:00:19 7494MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\ti2rehaia_4K_Albedo.tx"
00:00:19 7501MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\ti2rehaia_4K_Opacity.tx"
00:00:19 7508MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flexcera_Base_BaseColor.tx"
00:00:19 7514MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flexcera_Base_Roughness.tx"
00:00:19 7521MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flexcera_Base_Scattering.tx"
00:00:19 7530MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flexcera_Base_Scattering_Color.tx"
00:00:19 7547MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flex_BottleLabel.tx"
00:00:19 7560MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flex_BottleLabel_SpecMap.tx"
00:00:19 7564MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flexcera_Base_OriginalPink_211230_RM.tx"
00:00:19 7564MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Flexcera_Base_OriginalPink_Spec_211230_RM.tx"
00:00:19 7472MB | [AiMakeTx] maketx: no update required for "D:\Desktop_Health\DH_PROJECTS\DH_Lifestyle\02-c4d\tex\Icon_Power.tx"
00:00:19 7472MB | [c4dtoa] 20 Tx files have been generated
00:00:19 7472MB |
00:00:19 7472MB | authorizing with default license managers: rlm, network, user ...
00:00:19 7472MB | [user] authorized user "randymillsWYXAR"
00:00:19 7472MB | [user] expiration date: unknown
00:00:19 7472MB |
00:00:19 7473MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:19 7473MB | [color_manager_ocio] using config file C:\Program Files\Maxon Cinema 4D R25\plugins\C4DtoA\arnold\bin\..\ocio\configs\arnold\config.ocio
00:00:19 7473MB | [color_manager] rendering color space is "ACEScg"
00:00:19 7486MB |
00:00:19 7486MB | there are 51 lights and 1915 objects:
00:00:19 7486MB | 1 persp_camera
00:00:19 7486MB | 1 distant_light
00:00:19 7486MB | 43 quad_light
00:00:19 7486MB | 3 spot_light
00:00:19 7486MB | 1 skydome_light
00:00:19 7486MB | 3 disk_light
00:00:19 7486MB | 185 image
00:00:19 7486MB | 3 utility
00:00:19 7486MB | 1 flat
00:00:19 7486MB | 1 lambert
00:00:19 7486MB | 57 standard_surface
00:00:19 7486MB | 1 bump2d
00:00:19 7486MB | 1 mix_shader
00:00:19 7486MB | 1 abs
00:00:19 7486MB | 8 color_correct
00:00:19 7486MB | 1 curvature
00:00:19 7486MB | 2 layer_rgba
00:00:19 7486MB | 44 layer_shader
00:00:19 7486MB | 37 normal_map
00:00:19 7486MB | 8 ramp_rgb
00:00:19 7486MB | 2 shuffle
00:00:19 7486MB | 122 triplanar
00:00:19 7486MB | 3 two_sided
00:00:19 7486MB | 238 c4d_texture_tag
00:00:19 7486MB | 50 c4d_texture_tag_rgba
00:00:19 7486MB | 1 driver_exr
00:00:19 7486MB | 2 imager_denoiser_noice
00:00:19 7486MB | 2 imager_lens_effects
00:00:19 7486MB | 1 gaussian_filter
00:00:19 7486MB | 1 closest_filter
00:00:19 7486MB | 1059 polymesh
00:00:19 7486MB | 855 ginstance
00:00:19 7486MB | 3 list_aggregate
00:00:19 7486MB | 3 color_manager_ocio
00:00:19 7486MB | 1 c4d_noise
00:00:19 7486MB | 1 driver_c4d_display
00:00:19 7486MB |
00:00:19 7486MB | rendering image at 18144 x 7776, 4 AA samples
00:00:19 7486MB | AA samples max <disabled>
00:00:19 7486MB | AA sample clamp <disabled>
00:00:19 7486MB | diffuse samples 6 / depth 4
00:00:19 7486MB | specular samples 3 / depth 2
00:00:19 7486MB | transmission samples 3 / depth 8
00:00:19 7486MB | volume indirect <disabled by depth>
00:00:19 7486MB | total depth 10
00:00:19 7486MB | bssrdf samples 2
00:00:19 7486MB | transparency depth 10
00:00:19 7486MB | initializing 2741 nodes ...
00:00:20 7347MB | creating root object list ...
00:00:20 7347MB | node initialization done in 0:00.44 (multithreaded)
00:00:20 7347MB | updating 2742 nodes ...
00:00:20 7347MB | /LIGHTS/Hallway_Accents/Hallway_Sidelight: quad_light using 5 samples, 2 volume samples
00:00:20 7347MB | /LIGHTS/Cabinet_Upper/Cabinet_Upper_6: quad_light using 5 samples, disabled for volumes
00:00:20 7347MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_4: quad_light using 5 samples, 2 volume samples
00:00:20 7347MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_5: quad_light using 5 samples, 2 volume samples
00:00:20 7347MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_9: quad_light using 5 samples, 2 volume samples
00:00:20 7347MB | /LIGHTS/Hallway_Accents/Wood_Accents_Bottom_2: quad_light using 5 samples, 2 volume samples
00:00:20 7347MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_1: quad_light using 5 samples, 2 volume samples
00:00:20 7347MB | /LIGHTS/Hallway_Accents/Small_Plant_Spot: spot_light using 5 samples, disabled for volumes
00:00:20 7347MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_2: quad_light using 5 samples, 2 volume samples
00:00:20 7347MB | /LIGHTS/Projector_Lamps/Projector_Light: disk_light using 5 samples, 2 volume samples
00:00:20 7348MB | /LIGHTS/Cabinet_Upper/Cabinet_Upper_3: quad_light using 5 samples, disabled for volumes
00:00:20 7347MB | /LIGHTS/Hallway_Accents/Wood_Accents_Bottom: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Upper/Cabinet_Upper_4: quad_light using 5 samples, disabled for volumes
00:00:20 7348MB | /LIGHTS/Cabinet_Upper/Cabinet_Upper_2: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Arnold_distant_light: distant_light using 1 sample, 2 volume samples
00:00:20 7349MB | /LIGHTS/Hallway_Accents/Small_Plant_Spot_1: spot_light using 5 samples, disabled for volumes
00:00:20 7348MB | /LIGHTS/Cabinet_Upper/Cabinet_Upper: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_6: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_11: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Upper/Cabinet_Upper_5: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Hallway_Overhead/Hall_Overhead_5: quad_light using 5 samples, disabled for volumes
00:00:20 7348MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Hallway_Accents/Wood_Accents_Top: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Hallway_Accents/Picture_Spot: spot_light using 1 sample, disabled for volumes
00:00:20 7349MB | /LIGHTS/Hallway_Accents/Logo_Backlight: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Upper/Cabinet_Upper_1: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Hallway_Overhead/Hall_Overhead_3: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Projector_Lamps/Projector_Light_Hero: disk_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_10: quad_light using 5 samples, 2 volume samples
00:00:20 7348MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_12: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_2: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_7: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Projector_Lamps/Projector_Light_1: disk_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_3: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_6: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_4: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_5: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Arnold_skydome_light: skydome_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Hallway_Overhead/Hall_Overhead_6: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Overhead/Cabinet_Overhead: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_13: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_3: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_1: quad_light using 5 samples, disabled for volumes
00:00:20 7349MB | /LIGHTS/Cabinet_Kick/Cabinet_Kick_8: quad_light using 5 samples, 2 volume samples
00:00:20 7349MB | /LIGHTS/Hallway_Accents/Wood_Accents_Top_2: quad_light using 5 samples, 2 volume samples
00:00:20 7891MB | scene bounds: (-12.2935734 -5.23367596 -8.72223282) -> (5.29252863 4.19636917 8.27257538)
00:00:20 7891MB | node update done in 0:00.15 (multithreaded)
00:00:20 7891MB | [quad_light] /LIGHTS/Hallway_Accents/Hallway_Sidelight: 128x128 importance map done in 0:00.00, average energy 0.999291
00:00:20 7792MB | [quad_light] /LIGHTS/Cabinet_Overhead/Cabinet_Overhead: 512x512 importance map done in 0:00.11, average energy 0.080182
00:00:20 7847MB | [quad_light] /LIGHTS/Cabinet_Upper/Cabinet_Upper_2: 512x512 importance map done in 0:00.57, average energy 0.078522
00:00:20 7847MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_6: 512x512 importance map done in 0:00.57, average energy 0.007523
00:00:20 7847MB | [quad_light] /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_5: 512x512 importance map done in 0:00.57, average energy 0.080182
00:00:20 7847MB | [quad_light] /LIGHTS/Cabinet_Upper/Cabinet_Upper_6: 512x512 importance map done in 0:00.58, average energy 0.078522
00:00:20 7848MB | [quad_light] /LIGHTS/Cabinet_Upper/Cabinet_Upper: 512x512 importance map done in 0:00.59, average energy 0.078522
00:00:20 7848MB | [quad_light] /LIGHTS/Hallway_Accents/Wood_Accents_Bottom_2: 512x512 importance map done in 0:00.59, average energy 0.007523
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_3: 512x512 importance map done in 0:00.59, average energy 0.080182
00:00:20 7849MB | [quad_light] /LIGHTS/Hallway_Overhead/Hall_Overhead_6: 512x512 importance map done in 0:00.60, average energy 0.080182
00:00:20 7849MB | [quad_light] /LIGHTS/Hallway_Accents/Wood_Accents_Bottom: 512x512 importance map done in 0:00.60, average energy 0.007523
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_12: 512x512 importance map done in 0:00.60, average energy 0.007523
00:00:20 7849MB | [quad_light] /LIGHTS/Hallway_Accents/Wood_Accents_Top_2: 512x512 importance map done in 0:00.60, average energy 0.007523
00:00:20 7849MB | [quad_light] /LIGHTS/Hallway_Overhead/Hall_Overhead_5: 512x512 importance map done in 0:00.60, average energy 0.080182
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_6: 512x512 importance map done in 0:00.60, average energy 0.080182
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Upper/Cabinet_Upper_1: 512x512 importance map done in 0:00.60, average energy 0.078522
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Upper/Cabinet_Upper_5: 512x512 importance map done in 0:00.60, average energy 0.078522
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_4: 512x512 importance map done in 0:00.60, average energy 0.080182
00:00:20 7849MB | [quad_light] /LIGHTS/Hallway_Accents/Wood_Accents_Top: 512x512 importance map done in 0:00.60, average energy 0.007523
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Upper/Cabinet_Upper_3: 512x512 importance map done in 0:00.60, average energy 0.078522
00:00:20 7849MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_5: 512x512 importance map done in 0:00.60, average energy 0.007523
00:00:20 7849MB | [quad_light] /LIGHTS/Hallway_Accents/Logo_Backlight: 512x512 importance map done in 0:00.61, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Hallway_Overhead/Hall_Overhead_3: 512x512 importance map done in 0:00.61, average energy 0.080182
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_9: 512x512 importance map done in 0:00.61, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick: 512x512 importance map done in 0:00.61, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_4: 512x512 importance map done in 0:00.61, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_2: 512x512 importance map done in 0:00.61, average energy 0.080182
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_1: 512x512 importance map done in 0:00.61, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_3: 512x512 importance map done in 0:00.61, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_7: 512x512 importance map done in 0:00.62, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Upper/Cabinet_Upper_4: 512x512 importance map done in 0:00.62, average energy 0.078522
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_13: 512x512 importance map done in 0:00.62, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_8: 512x512 importance map done in 0:00.62, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Overhead/Cabinet_Overhead_1: 512x512 importance map done in 0:00.62, average energy 0.080182
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_10: 512x512 importance map done in 0:00.62, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_2: 512x512 importance map done in 0:00.62, average energy 0.007523
00:00:20 7850MB | [quad_light] /LIGHTS/Cabinet_Kick/Cabinet_Kick_11: 512x512 importance map done in 0:00.62, average energy 0.007523
00:00:20 7850MB | [aov] parsing 12 output statements ...
00:00:21 15971MB | [aov] registered driver: "/_display_driver_" (driver_c4d_display)
00:00:21 15971MB | [aov] * "RGBA" of type RGBA filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "Z" of type FLOAT filtered by "/_display_driver__Z_filter" (closest_filter)
00:00:21 15971MB | [aov] * "diffuse" of type RGB filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "emission" of type RGB filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "transmission" of type RGB filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "specular" of type RGB filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "albedo" of type RGB filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "shadow_matte" of type RGBA filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] registered driver: "/cryptomatte_driver" (driver_exr)
00:00:21 15971MB | [aov] * "crypto_asset" of type RGBA filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "crypto_object" of type RGBA filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] * "crypto_material" of type RGBA filtered by "default_filter" (gaussian_filter)
00:00:21 15971MB | [aov] done preparing 14 AOVs for 16 outputs to 2 drivers (0 deep AOVs)
00:00:32 66681MB | starting 64 bucket workers of size 64x64 ...
00:00:32 67080MB | [skydome_light] /LIGHTS/Arnold_skydome_light: 1000x1000 importance map done in 0:00.70, average energy 0.260247
00:06:05 67913MB | 0% done - 1319161 rays/pixel
So it crashed right after this? Or did it hang, and that's what you saw in the morning?
  1. 00:06:05 67913MB | 0% done - 1319161 rays/pixel
I'm wondering if there's subdivision and displacement happening after that, when the memory usage was already up to 68GB
The incredible number (1.3 million!) of rays/pixel is a bug, I think. Often at 0% the rays/pixel reported is way too high.
If you bring the samples way down (like back to the defaults), does it render with DOF? Or does DOF kill it no matter what?
If I had the scene, I'd try first with default sampling, and probably with Ignore Shaders and Ignore Textures, just to make sure it renders with DOF. Then starting add stuff back...
// Stephen Blair
