Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Do multiple references impact render time?
3 REPLIES 3
317 Views, 3 Replies
We're trying to get our node graphs under control at my office, and I am wondering if I reference the same network multiple times in a shader network will this affect performance? I am assuming that reference shaders are only evaluated once?
Also, how does the cache node fit in here? Should I place the cache on the outbound FROM the reference, or is it ok to place the cache inside the reference?
Tags (2)
Labels (2)
3 REPLIES 3
Stephen.Blair
References aren't going to affect performance.
And if you're using these references in shaders applied to different objects, then the cache node won't help.
If you're connecting the output of a reference to multiple inputs, all in the same shader tree, then a cache node might help. Especially if this is in a volume shading tree.
// Stephen Blair
// Arnold Renderer Support
Thank you @Stephen Blair. Specifically I am asking if multiple references to the same shader within another shader would affect performance:
Will both setups perform similarly?
Stephen.Blair
There's no difference between those two. After translation to Arnold, you end up with the exact same shader tree.
// Stephen Blair
