Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Distribute Still Image - Any script?
2 REPLIES 2
cdordelly09
332 Views, 2 Replies
Hi all! Anybody know about a script to put different images together if I use Distribute Still Image Over Frames? It works with a exr file with various AOV channels too?
I know a little bit of Python but I have never used it to intervene images.
Thanks!
Tags (2)
Labels (2)
2 REPLIES 2
tobiasYQQCF
in reply to: cdordelly09
A script is in the works that I will share as soon it is done.
As of now, you can load the rendered fils into a stack in Photoshop and they will be placed correctly.
Use File > Scripts > Load Files into Stack.
so the best way would be to render the OAVs to their own files and do the same thing to them.
Then when all those images are put together, do the script again to compile them all.
Randy_Mills1
in reply to: tobiasYQQCF
Hey Tobias, did you ever finish a script for this? Rendering out a 8' x 21' image now and about to dive into Photoshop this weekend to reassemble.
