Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
displacing/translating texture homogeneously using noise
4 REPLIES 4
203 Views, 4 Replies
Hi There !
i'm trying to displace a texture using a noise shader linked to the translate pin of the uv_transform node (+ a vector_map node to re-range noise value from 0/1 to -1/1 in order to center the displacement)
however i'm running into a problem, the displacement noise is mapped on a diagonal from -1 = [-x,-y] to 1 = [x,y], meaning the displacement is mapped on a diagonal.
I joined screenshots to clarify.
Is there any way to have the 2D noise in a way that the displacement is homogeneously mapped in every directions ?
4 REPLIES 4
peter_horvath
You offset both, the U and V coordinate with the same value, hence it looks diagonal. Maybe try another noise shader with a different seed on the V coordinate.
// Peter Horvath
// C4DtoA developer
Hi Peter, thanks for your answer, I understand the logic however I didn't find a way to connect 2 noise shader separately to the x and y of the translate pin of the uv_transform node, there is only one entry provided for the whole translate operation. I may have to "aggregate" them before ?
peter_horvath
Use a float_to_rgb shader, connect the two noise shaders to the R and G channels.
// Peter Horvath
// C4DtoA developer
ooh ! I forgot the use of RGB coordinates as XYZ ! thanks a lot !
Technology Administrators
