Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Default Standard Surface appears transparent.
2 REPLIES 2
217 Views, 2 Replies
When I apply a default surface shader material to an object, it's appearing transparent. Is this default behavior? What am I doing wrong if I want the Standard Surface Shader to appear completely opaque?
Tags (1)
Labels (1)
2 REPLIES 2
lee_griggs
This is what I get with the default standard_surface shader. Are you using the latest build?
Is transmission_weight 0 and opacity: white?
Lee Griggs
Arnold rendering specialist
AUTODESK
Figured it out. Ended up being the Arnold Color Management Settings for OCIO not set correctly. Once I fixed that, everything worked as anticipated. Thanks again!
