Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Cylinder projection creates bug
4 REPLIES 4
Daniel_Mikolajcak
279 Views, 4 Replies
Hello, I have a metal material, cylindrical mapping (other mapping are OK) creates white washed material. If I unplug normal map it is depicted correctly again.7557-screenshot-2020-07-02-at-100855.png
Tags (2)
Labels (2)
4 REPLIES 4
Are there any warnings or errors in the log? I could not reproduce it so far, it's probably depends on the mesh. Can you share this scene with me?
I have sent you the scene via weTransfer
This is an issue which was reported earlier and will be fixed in the next core release. Until then you can use this workaround: add an Arnold tag to the object and enable Generate UVs from the texture tag on the Export tab.
thanks peter
