Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Corona-like caustics
7 REPLIES 7
Message 1 of 8
Daniel_Mikolajcak
681 Views, 7 Replies
I do many Archviz renders of pools and Corona Renderer has much more superior and realistic caustics for this use case. Is there a plan to have such easy-to-use and beautiful looking caustics featured in Arnold?
(I have tried all possible arnold workarounds and none have delivered good results)
https://corona-renderer.com/features/rendering-quality
Tags (2)
Labels (2)
7 REPLIES 7
Message 2 of 8
Have you tried this?
https://docs.arnoldrenderer.com/display/A5AFMUG/Fake+Caustic+Effect
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 3 of 8
yes I have, It has not worked in a pool-filled-with-water scenario, best solution right now is to render Caustics pass in Corona and use it in the post
Message 4 of 8
Both rendered in Arnold one has caustics pass rendered in Corona laid over, it adds unprecedented emotion to it.
Message 5 of 8
I guess you need to use "fake" caustics. I honestly don't use caustics at all, because usually clients always want something more tone down. I believe is too "expensive" to calculate this type of effects. Corona has caustics true, but then it takes 17 hours to render a 5k image.
Ciro Cardoso
Message 6 of 8
I don't have impression it is that expensive in Corona, I have rendered caustics down below in about 30 minutes albeit not in 5K but 1440 p. You can also render part of image with caustics. I am also sure Corona caustics is some biased trickery.
Message 7 of 8
I agree that there are shortcuts to get those caustics.
Ciro Cardoso
Message 8 of 8
Not to dis on arnold, it does produce some nice subtle soft caustics. But it just don't do the job for rippling pools.
