Converting Redshift materials to Arnold
Brian_Re
Message 1 of 10
Brian_Re
is there a way or a script to convert redshift materials to Arnold ,since both redshift and Arnold share the same node names and setting , now there is only a conversion from C4D materials to Arnold , which doesn't work on redshift materials
Replies (9)
Message 2 of 10
lee_griggs
Have you tried any of the conversion scripts in the Arnold -> Utilities menu
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 10
peter_horvath
The current conversion scripts are for the Standard Material, no conversion for Redshift Materials. We'd like to add it in a future release, but no ETA at the moment.
// Peter Horvath
// C4DtoA developer
Message 4 of 10
Brian_Re
its doesn't work on RS materials .
Message 5 of 10
Brian_Re
is there any work around , maybe converting to another render engine then convert to arnold ?
Message 6 of 10
peter_horvath
Don't think there's any workaround for this, other than writing your own conversion script, which is not trivial.
// Peter Horvath
// C4DtoA developer
Message 7 of 10
sakebmakeb
Yes, the redshift converter only converts from c4d materials. And I also found and tried the poliigon tool. Didn't help either. I know that I ll have to do at least the fine tuning manually. But a little help by a script would come in handy.
Message 8 of 10
peter_horvath
I'll try to put together a basic script when I have some time, probably next week.
// Peter Horvath
// C4DtoA developer
Message 9 of 10
peter_horvath
Hey, Finally I had some time to write you a script, sorry it took so long. It supports Standard Material, Texture, Bump Map, Normal Map and Displacement currently. It's very basic, just copies over the values for standard surface and sets the filename on the textures. I'm pretty sure there will cases where the look don't match and you need to adjust the values. But it should be a good starting point.
// Peter Horvath
// C4DtoA developer
Message 10 of 10
Brian_Re
its works fine ,it crashes sometimes and creates duplicates of some node for some reason . but overall its good , thanks a lot ,I appreciate your help .
