Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
coloring splines according to their length
7 REPLIES 7
Message 1 of 8
387 Views, 7 Replies
Hi there ! I got a Xparticles simple setup that generates a bunch of trails/splines and I wanted to know it was possible to export le splines/trails length to the arnold material in order to color each trails according to its length (ie using a gradient) ?
Labels (4)
7 REPLIES 7
Message 2 of 8
peter.horvath6V6K3
Sorry for the late reply. Use a state_float shader with the v variable.
Message 3 of 8
Hi ! thanks Peter for the answer ! this method to add gradient to splines works perfectly, so I'll keep it in mind 😉
however I didn't express my self clearly, I'm looking for a method to color each splines uniformly (not a ramp mapped along each ones) with one color picked from a gradient according to the length of each one
ie : I create a ramp from yellow to red and I want the shortest splines to be yellow and as they get longer they get closer to red (but one color per splines, not the gradient mapped over it)
is this possible with arnold (it's possible with cycle 4d but I prefer to keep everything in arnold 😉 )
Message 4 of 8
peter.horvath6V6K3
Gotcha. Don't think it's possible in the current build, but this would be a nice addition for a future release. Having a flag to export the length of each splines as a user data.
Message 5 of 8
lee_griggs
You might get something out of the color_mode in the utility shader. Maybe v_coord, barycentric and Object ID in combination with a color_correct to fine-tune it.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 6 of 8
Hi ! thanks for your answers ! i'll try that this afternoon !
about user data i was close to solution with xpresso (the spline node is actually able to compute a spline length, unfortunately if you give a flock of trails, which are considered segments of the same spline, you can only output one length at a time with a provided segment index, I didn't manage to export a matrix of indexed length)
anyway i'll play around with lee griggs suggestions 😉 !
Message 7 of 8
lee_griggs
v_coords may work better.
Lee Griggs
AUTODESK
Message 8 of 8
in reply to: lee_griggs
sounds great ! thanks !
