Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
closest_filter displays black in IPR render region with adaptive sampling
1 REPLY 1
AJUKking
136 Views, 1 Reply
The render region will render completely black in the IPR. This seems to be caused when in the render settings "Default filter . Type" is set to "closest_filter" and adaptive sampling is enabled with a "AA samples max" increased a few levels. The render region seems to render fine though until it finally finishes and outputs the final render pass level, which in this case is just black.
Tags (1)
Labels (1)
  • IPR
1 REPLY 1
Thanks for reporting the issue, I could reproduce it. Investigating.
