Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
cinema4d turned off
1 REPLY 1
starcolor_a
134 Views, 1 Reply
cinema4d turned off
저는 시네마 4D 사용자입니다.
Arnold Render를 업데이트하기 전에는 프로그램이 거의 꺼지지 않지만 업데이트 후에는 종종 꺼집니다.
이 문제를 해결할 수 있습니까?
Tags (1)
Labels (1)
1 REPLY 1
Which version of C4DtoA do you have installed? There were some instability issues in 4.0.0, so please update to 4.0.1.
If you are using C4DtoA 4.0.1, please send us the _BugReport.txt from the folder on your screenshot and the minidump.dmp located in the same folder.
