Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Cinema 4d shaders
3 REPLIES 3
yox_vox
248 Views, 3 Replies
Cinema 4d shaders
I need to ask you. How many C4d shaders are supported in arnold.
Thank you
Tags (1)
Labels (1)
3 REPLIES 3
ulrichGTAV3
in reply to: yox_vox
As far as I know only C4D Noise. And cloner / vertex / object color via "data_user_rgb" node.
cheers...
ulrichGTAV3
in reply to: ulrichGTAV3
actually, I don't know about vertex color. But there is a "vertex map" node...
Yes, as you said, C4D Noise, Bitmap, Vertex Map, Substance Shader and the Display Color of objects via the user_data_rgb shader.
https://docs.arnoldrenderer.com/display/A5AFCUG/Cinema+4D+Shaders
Technology Administrators
