Now I've removed every plug but c4dtoa and I still get crashes. I've removed and installed c4d and also the latest c4dtoa. And still it freezes the program, at random places. Sometimes it can render 360 frames without any problem and sometimes just a 30ish. And sometimes it happens when it autosaves or I'm saving the scene, but that's not happening every time, so hard to know what's causing this.
I've got a reply from maxon on the subject too:
Thank you for reaching out to us and sorry for your issues using our software.
The crash still has been caused by Arnolds render plugin (c4dtoa.xdl64).
To avoid further crashes remove the plugin from your installation of Cinema 4D or try to install the latest version of this plugin.
You should inform and describe this problem to the developer of the plugin to assure he can reconstruct the issue and fix the problem.
Maxon itself cannot install, test or support 3rd party plugins.
Please be aware, that every installed plugin could cause crashes every time, as they are loaded at startup of the program.
It does not matter if the plugin is used during your work or not.
I hope this information helps.
