Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Cinema 4D Arnold Render looks different as in IPR window.
5 REPLIES 5
lukaszmdx
1155 Views, 5 Replies
I am trying to recreate the effect from this clip https://www.youtube.com/watch?v=Neu8u9Lpwzg where the object goes though a jelly like bubble, to animate it I have used Jiggle modifier with turbulence and attractor forces applied. The problem is that the IPR window (on the right) shows somewhat my desired result however the actual render (on the left ) seems to ignore the my desired deformations applied to the sphere.
Anyone knows of possible solution?
Tags (1)
Labels (1)
5 REPLIES 5
Stephen.Blair
in reply to: lukaszmdx
Please check the Arnold log
// Stephen Blair
// Arnold Renderer Support
lukaszmdx
Ohh, I have it figured out. It was enough to Cache the Jiggle modifier. After that the render did match the IPR preview.
Thanks for reply Stephen 😄
Stephen.Blair
ah right. now I remember I had a case with Jiggle and caching
// Stephen Blair
The IPR is attached to the viewport, while the actual render operates on a 'prepared' scene. This can make a difference, for example if you have a simulation (e.g. X-Particles) and you jump frames or move backwards, then the viewport shows a different state, not the actual final simulation. I guess this issue with the Jiggle modifier could be something similar.
That makes a lot of sense, thank you Peter 😄
