Every time I render it seems like the model is invisible for more and more frames.
I tried caching the scene dynamics and it is only visible for one frame.
Arnold Picture Viewer started at Tue Mar 25 14:06:30 2025
[c4dtoa] 00:00:01 14976MB WARNING | resetting parameter vlist on /Abra_astronaut/astro_body_tyFlow007Low002 (found: nans or infs)
[c4dtoa] 00:00:04 16803MB WARNING | [disp] /asteroid_highpoly_2: padded bounds could be 70x more efficient. given disp_padding: 0.0170000009, recommended: 8.77305865e-07
Degenerate polygon objects found in frame: 94
Degenerate Object: astro_body_tyFlow007Low002
[c4dtoa] 00:00:00 15113MB WARNING | /tool_case_1_Astronaut/top_low/topfoam_low: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15114MB WARNING | /detonator_cable_sweep|detonator_cable_sweep: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15115MB WARNING | /asteroid_highpoly_1: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15125MB WARNING | /asteroid_highpoly_2: parameter "opaque" is deprecated
Arnold Picture Viewer started at Tue Mar 25 14:06:51 2025
[c4dtoa] 00:00:01 15003MB WARNING | resetting parameter vlist on /Abra_astronaut/astro_body_tyFlow007Low002 (found: nans or infs)
[c4dtoa] 00:00:04 16711MB WARNING | [disp] /asteroid_highpoly_2: padded bounds could be 70x more efficient. given disp_padding: 0.0170000009, recommended: 8.77305865e-07
Degenerate polygon objects found in frame: 95
[c4dtoa] 00:00:00 15282MB WARNING | /tool_case_1_Astronaut/top_low/topfoam_low: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15283MB WARNING | /detonator_cable_sweep|detonator_cable_sweep: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15283MB WARNING | /asteroid_highpoly_1: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15293MB WARNING | /asteroid_highpoly_2: parameter "opaque" is deprecated
Arnold Picture Viewer started at Tue Mar 25 14:07:12 2025
[c4dtoa] 00:00:01 15077MB WARNING | resetting parameter vlist on /Abra_astronaut/astro_body_tyFlow007Low002 (found: nans or infs)
[c4dtoa] 00:00:04 16753MB WARNING | [disp] /asteroid_highpoly_2: padded bounds could be 70x more efficient. given disp_padding: 0.0170000009, recommended: 8.77305865e-07
Degenerate polygon objects found in frame: 96
[c4dtoa] 00:00:00 15201MB WARNING | /tool_case_1_Astronaut/top_low/topfoam_low: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15202MB WARNING | /detonator_cable_sweep|detonator_cable_sweep: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15203MB WARNING | /asteroid_highpoly_1: parameter "opaque" is deprecated
[c4dtoa] 00:00:00 15212MB WARNING | /asteroid_highpoly_2: parameter "opaque" is deprecated
